Thread: Lose of power?
Created on: 04/18/15 07:17 AM
SlowBen
SlowBen's Gravatar
Lose of power?
04/18/15 7:17 AM
I have lost the power wheelie in 2nd gear. Use to go WOT around 4k and would be pulling the front by 6k to 7k now nothing. Any ideas
Speed is an allusion of previous experiences
2013 ZX14R AH2 with Cblast flash,yoshi fender eliminator, stompgrip tank pads, ASV levers.
Nastynotch
Nastynotch's Gravatar
RE: Lose of power?
04/18/15 7:25 AM
Traction is everything. What's the condition of the tire?
2013 ZX-14R SE
2 Wheel dyno works flash
Muzzys black stainless slips
V1 custom mounted
Zero Gravity DB screen
Yoshimura fender eliminator
Black powder coated wheels
carabuser
carabuser's Gravatar
RE: Lose of power?
04/18/15 8:40 AM
Hmm how many miles ? if its not the tires, somethings wrong, mine comes right up in second, especially with
the Cblast flash !!! i accidentally did it right in front of a cop one time, when I was getting on the
freeway !! LOL !!
Predator Race Team #14
Hayabusa
1980 GS 1100
1978 GS 550
1968 CL 350
1972 TS 90
Winston Churchill
maverick1441
maverick1441's Gravatar
RE: Lose of power?
04/18/15 8:57 AM
Is the engine pulling smoothly? Could possibly be clutch slippage if the RPMs seem to run ahead of where you'd normally see them. Check for brake drag. Seems dumb but make sure you didn't leave a TC mode on or power mode in L.
SlowBen
SlowBen's Gravatar
RE: Lose of power?
04/18/15 9:19 AM
The has 1800 mi. The rear tier is starting to flatten out a little bit come up in first noproblem. I don't think the clutch is slipping think being the main word there. TC is off. Chain is lubed up. The motor seems to run fine. Breaks are not dragging. I'm lost here man.
pegscraper
RE: Lose of power?
04/18/15 10:55 AM
To check for clutch slippage choose a private road or airstrip get in 4th or 5th around 7-7500 rpm where max torque is and accelerate hard. This is where the clutch is under real pressure, more so than trying to lift the front in 2nd and any slippage should be more obvious. If the rear tyre has gone off I would expect it to lift the front easier in 1st than 2nd. JMO
Nastynotch
RE: Lose of power?
04/18/15 11:07 AM
not in my experience.
2013 ZX-14R SE
V1 custom mounted
zx14rider345
zx14rider345's Gravatar
RE: Lose of power?
04/18/15 12:53 PM
When did you do the AH2? If you just installed it I know I lost low end torque in the lower RPM'S when I put the shorty CT Meg on vs the stock exhaust anyway.
2012 ZX14R, 2016 BMW S1000XR
RE: Lose of power?
04/18/15 1:45 PM
1. Check compression or chase your tail.
2. The plugs are pulled so replace them.
3. Sync the throttle bodies.
4. That's all bulletproof needs is some freshening up... say the odds.
RE: Lose of power?
04/18/15 1:47 PM
I lose power every spring and fall,but boy does she ever put down these long black strips,cold roads poor traction
SlowBen
SlowBen's Gravatar
RE: Lose of power?
04/18/15 2:34 PM
Check compression with only 1800mi. Could plugs be bad already. And throttle body out of sync. If any of these is the problem it's going back to the dealer.
skewedTotheLeft
RE: Lose of power?
04/18/15 2:47 PM
My bike will power wheelie in second even with the swing-arms extended 4.75 inches and lowered 1.25 inches. Of course for traction I use the very sticky Shinko Hookup drag radial on the rear.
* Last updated by: skewedTotheLeft on 4/18/2015 @ 2:48 PM *
maverick1441
RE: Lose of power?
04/18/15 3:21 PM
You could pull your air filter and check to see if you've got a restriction.
runnerhiker
runnerhiker's Gravatar
RE: Lose of power?
04/18/15 3:27 PM
That bike is too new to have a power problem. Check the traction control and power control settings.
dehaile
dehaile's Gravatar
RE: Lose of power?
04/18/15 5:45 PM
How hot is it where you are today? Are you at altitude. My bike in Colorado Mountains really loses power but the corners are worth it! :)
2013 ZX14R ABS
Nightmare
Nightmare's Gravatar
RE: Lose of power?
04/18/15 9:03 PM
1,800 miles is probably the best time to check your compression and make sure you write these numbers down (front of your service manual is a good spot). Even if the numbers look good, now you have a point of reference for future compression tests. If there's a big difference between cylinders you may have uncovered a major issue while the bike is still under warranty. Worst case you spent an hour of your day and recorded some great info.
RE: Lose of power?
04/18/15 10:25 PM
Slow, I do not think you are that slow. Oh look, Moe! I'm going to go right down to the dealer and show them my tire is this flat wear pattern. Whereas, I'm squeezing out more than 4k out of the OEM before I changed them out? And is this one of those, cough, internet break-ins and not a book followed break-in and how do you explain a flat spot within 2k miles? Are you going to snow me at the drive you rolling up and I check the tire wear to my break-in miles vs yours?
I don't think it's the clutch either. I think it's broken-in.
The motor seems to run fine. I'm lost here man.
If I have all those parameters in check and I still can't find jackshit, do we go back and forth you see me checking the health of the shit I beat to death? Of course you do. Would I chase my tail with all new looking plugs and air cleaners and no codes on the dash; as if there is a problem? Or do we look the fool we keep being lost in the search. Brain the drain wash you with the very first basic move and go on from there or chase your tail; home he does not suffer those fools rubbing their balls; scratching their dicks; because I am out of this thread. It says; I'm just as lost w/out comp numbers sent forward.
* Last updated by: Hub on 4/18/2015 @ 10:25 PM *
SlowBen
SlowBen's Gravatar
RE: Lose of power?
04/19/15 5:53 AM
Hub, you are right I didn't stay under 4k but I also didn't beat the s#it out of it. Your advice is well heard and I will check compression. I will be looking at everything very closely tomorrow. Here is a pic of my tire.
RE: Lose of power?
04/19/15 6:49 AM
Holy shit son... you got to find some curves. you ain't even rolled over your elephants yet!
SlowBen
SlowBen's Gravatar
RE: Lose of power?
04/19/15 7:52 AM
Vic, I will work on that for you sir. Haven't had to many warm days that I didn't have to go to work. That's my excuse anyways lol
carabuser
RE: Lose of power?
04/19/15 10:07 AM
I think I found your problem, it's the Metzlers !!!! haha ! seriously though, one of the
best things I did, was get rid of the metzlers and put on PR4's just sayin .....
Hayabusa
1980 GS 1100
1978 GS 550
1968 CL 350
1972 TS 90
Winston Churchill
SlowBen
SlowBen's Gravatar
RE: Lose of power?
04/20/15 1:14 PM
Well my power is back. Took it out and tried some the things you all recommend. My clutch wasn't slipping but what I found out with some help of Cblast is that my plugs were fouled out from me riding back and forth to work. I have been riding to work as much as possible witch is 25mi one way and it is highway that is cop central. Needless to say I putt the hole way 60mph. Got out to day and rode it hard and it came back to life 2nd gear wheeling back in session and the lovely 3rd gear lift. That's for the help guys.
SlowBen
SlowBen's Gravatar
RE: Lose of power?
04/20/15 1:19 PM
Vic I work on that a little to day for you. It's been raining just starting to dry up. And carabuser I plan on getting the PR4 when These are done.
